29. jan 2007 22:59
Trunk emblem removal
Hi!
Any ideas if the trunk emblem can be removed easily with a hot air gun or will it leave marks ie. does the emblem have studs etc. in it?
Thanks in advance!
-Antti
*);:...www.AllShowNoGo.com...:;(*
-modified is how we roll-
29. jan 2007 23:10
you can do it with a string of some sort.. i did mine without any heat.. and it have none studs
30. jan 2007 08:39
I heated it up with my wifes hairdryer, and removed the emblems very carefully.
No marks left on the trunk. The glue - if any left - is easy to remove with your fingers smilie
Good luck to you smilie
30. jan 2007 09:28
Thank you guys for the help!
It is much appreaciated =).
Swifts are still quite uncommon here in Finland and mine is propably among the first 10 here with any tuning of any sort smilie
30. jan 2007 12:18
We will see your car smilie
Put up some pictures in our gallery - Please smilie
30. jan 2007 19:46
Not with these wheels on! =).
Just kidding.
I'll add some next week after the ICE install =).
2. feb 2007 09:09
Antti, use some sewing thread and carefully file the glue off by pulling it slowly from side to side, then the rest of the glue can be removed by using a solvant of some sort.
