21. mar 2008 09:43
Fælles køb: BILLIG gevind undervogn
Hej Drenge.
jeg har fået muligheden for at skaffe os nogle røv billige gevind undervogne til vores små swifter..
Der er tale om følgende:
D2 Racing Suspensions are a complete set of Four units made from Mono-tube design (same technology to ones features in Tein, HKS, Cusco coil-over suspension) shock absorbers filled with Nitrogen (30%) and Oil (70%) that is designed to reduce oil leaking defects. Lightweight aluminum alloy material are used to manufacture the D2 Racing Suspensions to ensure durabilty and Teflon coated lock rings for Rust prevension, unlike most other brands these have piston dust boots with built in Bump stops
36 points of damper adjustments means you can fine-tune your vehicle for whatever the circuit calls for from Soft for street driving to Hard for track use. It can also be disassembled and rebuilt as well to meet with whatever the circumstances.Easey Damper adjusment with Twist dials from the top of the Suspension.
D2 also features height adjustments to lower the vehicle up to 110mm lower than standard ride height for better center of gravity or can be used and set at the OEM ride height.
Pillow ball top hats means camber adjustments can be adjusted at ease and is available for all car models that use Mc Pherson Style suspension,Where not applicable the standard top hats are used as in most European cars or D2 Solid Top plates are used with Hard Bushing.
All kits come with a D2 Tool bag which includes Ring spanners and oil line brackets where applicable.
All components are manufactured in United Kingdom and assembled in Taiwan.
All suspension units come with a 6 month Warranty for replacement parts found to be defective, From Performance Guru within normal use and not road abuse , there after all parts can be sourced.Warranty is void if used for Track Racing.
All D2 Suspension units are TUV ISO 9001 : 2000 Approved ( Special German TUV can be Supplied )
Prisen på sådan en svend kommer til at ligge på lige omkring 5000kr, dog vil jeg se om vi ikke kan opnå lidt mængde rabat hvis der nu er 10 af os som vil have 1...
Status: 3 Solgte
1 stk Simon da Silva
1 stk HypeTaxx
1 stk Kenneth J
21. mar 2008 10:05
Fedt initiativ smilie
Jeg kunne måske godt ende med at være med på sådan en smilie
21. mar 2008 10:18
Jeg har lige snakket med leverandøren.. han har ikke så mange på lager da det er noget nyt han lige har taget ind i sortiment.. så vi skal være lidt hurtige.. Hvis vi til sammen kan komme op på 10stks så kommer der også en fin rabat med i købet som kommer alle til gode..
Lige pt. er vi på 2 hvis vi medregner HypeTaxx på..
21. mar 2008 11:29
Cool ide. Jeg er med også hvis det bliver omkring 5000kr smilie
Kenneth Jensen
21. mar 2008 11:30
#3 det bliver 5000kr eller mindre..så er vi oppe på 3 stks indtil videre.. smilie Super..
21. mar 2008 12:55
De koster da normalt under 5000, så må det jo blive meget billigere med 10 stk ?
21. mar 2008 13:00
Okay hvor har du fundet dem billigere endnu?
Jeg har kun haft fundet dem til 5,5k + fragt fra england...
21. mar 2008 13:09
De findes til £425 + £60fragt, hvilket svarer til 4600 KR... Har sendt besked til dig Hype!
21. mar 2008 13:18
Det er nogle ca. priser jeg har oplyst for at se hvor mange jeg kan få til at købe.. ved. 10 folk som køber vil vi opnå noget i stil med 10% rabat på dem..så skal jeg lige have kigget på fragten for at se om den også bliver billigere..
22. maj 2008 23:00
Ikke for at ødelægge noget, bare så folk er sikre på hvad de køber, undervognene er IKKE TÜV godkendte, det er firmaet, men det hjælper ingenting, bare lige så i ved det til syn.
Rigtig fin undervogn, har det på begge mine biler, bare lidt hårde, og prisen fejler bestemt ikke noget smilie
23. maj 2008 10:43
hva hjælper det a få dem på
23. maj 2008 11:55
Du kan selv indstille den undervogn så passer til din kørestil og ikke mindst den højde der passer i forhold til dine fælge, skørter osv...
12. sep 2010 16:48
er os med på en til min os vis de er billig
12. sep 2010 17:12
undskyld men tråden er 2 år gammel efterhånden smilie
12. sep 2010 19:42
Og Silva? Så må du skaffe dem igen!! smilie hahahah :P
