Vejledning til udskiftning af klodser på Swift 05
(Klippet fra værkstedshåndbogen)
Front Disc Brake Pad Removal and Installation
Removal
1) Loosen wheel nuts and with vehicle lifted up, remove
wheels.
2) Remove caliper pin bolts (1).
3) Remove caliper (1) from caliper carrier (2).
NOTE:
Hang removed caliper (1) with a wire hook (4)
or the like so as to prevent brake hose from
bending and twisting excessively or being
pulled.
Don’t operate brake pedal with brake pads
removed.
4) Remove brake pads (3).
Installation
1) Before installing brake pad shim, apply small amount
of pad grease “a” (included in pad kit) to mating
surfaces of brake pad (1) and pad shim (2).
WARNING:
Do not apply grease on pad lining surface.
2) Set brake pad springs (1) and shim (2) and install
brake pads (3).
NOTE:
For right side brake, install pad with wear
indicator (4) to vehicle center side.
3) Install caliper and tighten caliper pin bolts (a) to
specified torque.
Tightening torque
Caliper pin bolt (a): 26 N•m (2.6 kg-m, 19.0 lb-ft)
4) Install wheel and lower lift.
5) Tighten wheel nuts to specified torque.
Tightening torque
Wheel nut (a): 85 N•m (8.5 kg-m, 61.5 lb-ft)
6) After completion of installation, check for brake
effectiveness.
kan hentes som pdf
her (dowload begynder efter 30 sek) (kun aktiv i 7 dage)
