http://dl.dropbox.com/u/1539291/NewSwift_Workshop_Manual_RS415.pdf
Tjek side 402, der skriver de om hvordan man skifter manifolden:
1) Disconnect negative cable at battery.
2) Remove front bumper with front grille referring to “Front Bumper and Rear Bumper Components: in Section 9K”.
3) Remove radiator referring to “Radiator Removal and Installation: in Section 1F” for equipped with A/C.
4) With hose connected, detach A/C condenser from vehicle body for equipped with A/C.
5) Disconnect heated oxygen sensor No.1 connector (1) (connector color: green) and heated oxygen sensor No.2 connector (2) (connector color: gray), and then detach it from its stay.
6) Remove exhaust manifold stiffener (1).
7) Remove heated oxygen sensors (3) from exhaust manifold and exhaust No.1 pipe, if necessary.
8) Disconnect exhaust No.1 pipe (2) from exhaust manifold.
9) Remove exhaust manifold (1) and its gasket from cylinder head.
